Cart incrementing item quantity by one when cart is refreshed or back button is clicked
Aug 05, 2015 Aug 05, 2015
We recently upgraded to CF11 from CF9 and have ran into a challenge. I understand this is probably very fundamental but I am at a loss to figure it out because our cart worked so well for years before. I pass a url variable to the cart containing the sku number and it populates my preorder table with a quantity of one unless I also pass the quantity variable in the same string at which I use if isdefined to detect. My cart works but upon page refresh or if the back button is hit, it will increment one to the quantity field. Can someone tell me the way to eliminate this issue? In the address box of the old cart we hid the variable in the url string when passing the call to the cart but the same code not with CF11 does indeed show the variable(sku) in the url which is passed causing the cart to update. Looking for help here please?
345
Advocate ,
Without seeing some code its very hard to tell you what needs to be done. We don't know if you have done something in your code that worked in CF9 but should be done another way and now works as intended in CF11 etc
If you are unable to post the actual code, then you will have to write a example based on what you have done.
Thank you, I will post a sample of our code.
This is how we send the variable to the page that processes the data transaction:
<label onClick="location.href='shop/?sku=#sku#'">Add to Cart</label>
From there it is simply a SQL statement:
<cfif CheckCart.RecordCount GT "0">
<cfset myqty = (#CheckCart.Qty# + #Qty#)>
<!--- If there are already items in the cart then increment quantity --->
<CFQUERY datasource="Product" name="IncrementQuantity">
  UPDATE tblTempOrders
  SET Qty = <cfqueryparam cfsqltype="CF_SQL_INTEGER" value="#myqty#">
  WHERE CartID = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" value="#Cookie.CartID#">
  AND PartNo = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" value="#PartNo#">
</cfquery>
<!--- Otherwise, just add it to the basket --->
<cfelse>
  <cfquery datasource="Production" NAME="CartInfo">
   SELECT tblProduct.ShortDesc, tblFlagProduct.ShipType
   FROM tblgProduct
   WHERE tblProduct.NPart = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" value="#PartNo#">
            AND CurrentWeb = 'Y'
  </cfquery>
</cfif>
What is puzzling to me is that the url in the address bar does not show the sku number but when mouse is hover over submit button it does show. So in the address bar is indicates : http://mysite.local/force.cfm but hovering over the "ATC" button is shows https://mysite.local/shop/?sku=X12345
I hope this helps and appreciate your reply
Engaged ,
The one thing I would to is eliminate all the different queries and do the update/insert as one statement.  The query you show in your sample to add to the basket is a select so I am not sure how you are doing the insert.
  if exists(select 1 from tblTempOrders where CartID = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" value="#Cookie.CartID#">
    AND PartNo = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" value="#PartNo#">)
  begin
    SET Qty = qty+<cfqueryparam cfsqltype="CF_SQL_INTEGER" value="#qty#">
  end
  else
    <!--- do insert query here --->
  begin
  end
</cfquery>
Thank you for your replies. There are multiple reason we use this type of if / else cart functions. Many products will trigger different events upon qty so the segregation was necessary, at least at the time we built this, and has worked very well up until this upgrade. The url variable is also a triggered event in as much as if it is present (isdefined) in the transaction or it is not. I do appreciate the ideas but I am still at a loss. Thank you all again.
Documentation
