Where can I go to format the spacing between bullets and numbers and the text that follows them?
Open the two CSS files in a text editor and look for differences. Do the same with the topics. There will be a difference somewhere.
Post back if still stuck.
It's all controlled by the RH Styles and/or your CSS that's applied to the HTML pages. Does the HTML think you've got ordered lists and unordered lists in this sample?
That I get, and for this I was using the default .css. But I can't believe the default would have that wide a space and when I go in to edit, I don't see any place to adjust between the list style and the text.
Create a new single topic project and use the default CSS in that to recreate the same content (don't cut and paste it).
Does the problem still occur?
I created a new project and tried it and the spacing was correct. Please don't tell me my project is corrupt.
Found it by the comparison. I found one topic that had both the correct and incorrect setting. It was in the paragraph style. Thanks for all your help. I appreciate it!
Hi Geri
Perhaps you might consider posting the differences you found and what exactly fixed it for you? That might help others a little more down the path if they have the same issue.
Thanks... Rick
Defaults just set something up – they don’t necessarily make it look pretty. It also depends on what browser you use to look at the code too.
