I'm trying to generate a .docx file using RoboHelp HTML version 11, but RH keeps getting stuck on Saving <file name>. Any ideas?
Guest
Aug 06, 2015 Aug 06, 2015
I am trying to generate a .docx file using RoboHelp HTML version 11, but RH keeps getting stuck at 'Saving <file name>. Any ideas?
338
Which version of Word are you using?
Does it also stick if you try to generate a DOC file?
@petergrainge
Guest
We are using Word 2010. It gets stuck on saving when we try to generate a .doc and a .docx. It is a file a coworker is assigned. Adter posting this quesiton, I noticed that the RH files have tables embedded in tables and I know that Word is picky with tables.
So the problem is specific to this one project?
Can you post a screenshot of the dialog when it is stuck? (Use the web interface to the forum)
@petergrainge
Guest
It is happening with another project.
Guest
I was able to create 2 .docx files by just using about half the files in the project and copied and pasted the content into one .docx file. Not the best work around. But OK for now.
Aug 07, 2015 Aug 07, 2015
Normally problems that are fixed by generating two documents occur during generation rather than when saving.
I think that also rules out any Word compatibility issues or the content causing problems. If that were the cause then it would occur during generation of the Word document, not at the point of saving it.
Try one thing. Generate the document and then make some very small change, add a few words somewhere, then save. After cancelling the Save operation, open the document and see if the changes were saved. I have seen problems in another app that fails to complete on screen but does save.
You say the problem occurs with another project. Is that on the same machine and does it occur on other machines from the same projects?
@petergrainge
Participant ,
Instead of generating DOCX files for the entire project, try only (say) a chapter at a time. In this manner, this might help you identify what is causing RoboHelp to stall.
Once you have isolated the bad topic, try inspecting its HTML for anything irregular in the formatting.
If you're concerned about compatibility between MSWord and RoboHelp, then you could try installing Word 2013 as a 30-day trial.
RoboHelp Documentation
Download Adobe RoboHelp
