После запуска flashplayer18pp_fa_install появляется пустое окно Adobe Download Manager и всё. Как бы обновить Flash Player для Windows 7?
Hi vlad200204,
That's because you installed the NPAPI plugin. You need the PPAPI plugin for Opera. I included the link to download the PPAPI installer file in my previous post.
Maria
Hi vlad200204,
Did you move the installer file from one machine to another? If so, please try the following:
Maria
К сожалению, это не помогло. Спасибо за мысль.
Unfortunately, it didn't help. Thanks for thought.
I'd like to get the log files for the online installer from you. Please do the following
The offline installer, posted at the bottom of the Installation problems | Flash Player | Windows in the 'Still having problems' should work. Please do provide the online installer log files so that we can investigate further.
Thank you.
Maria
Hi
Adobe_GDE.log not create
Adobe_ADM.log until it stops
Adobe_ADM.log after close Adobe Download Manager
Thank you.
Thank you. I have forwarded this to the online installer team to investigate further. They may contact you for more information.
Did the offline installer work?
Maria
Сейчас установлен Flash Player версии 17.0.0.169 через online или offline не помню ...
Version 17.0.0.169 Flash Player through online or offline is established I don't remember ...
17.0.0.169 is an older, vulnerable version. The latest version is 18.0.0.209. The installer for this version is posted on the page I linked to previously.
Maria
Hi. Yes, this dialogue began with it: I start flashplayer18pp_fa_install, and instead of updating there is an empty window Adobe Download Manager
Hi vlad200204
Since the workaround is not helpful on your system, are you willing to do a screen share session with Adobe engineers so that we can debug the issue on your machine and resolve it for you? You can select the time based on your convenience.
Sreeharsha
Hi Sreeharsha
я готов сделать screenshot для инженеров Adobe и выполнить рекомендации по изменению (install, deinstall) программ windows, то есть устранить причину, мешающую обновлению flash player
I am ready to make screenshot for engineers of Adobe and to implement recommendations about change (to install, deinstall) the windows programs, that is to eliminate the reason disturbing to the flash player updating
Hi vlad200204
Can you verify if the offline installer, posted at the bottom of the Installation problems | Flash Player | Windows in the 'Still having problems' worked for you?
If it returns an error please take a screenshot (see How to post a screenshot in the forum) of the error and post it in your reply.
Maria
Hi Maria
update не происходит
update doesn't occur
Hi vlad200204,
That is the online installer, that we know is not working. I am asking you to try using the offline installer posted at the bottom of the Installation problems | Flash Player | Windows page.
Are you available now for a screenshare session? If so I will send you a link via private message.
Maria
Hi Maria,
install_flash_player_18_plugin установился, но Opera его не видит
install_flash_player_18_plugin was established, but Opera doesn't see it
Hi vlad200204,
Opera switched to the PPAPI plugin with Opera 25. It still recognized the NPAPI plugin several more versions, but I have found that the latest version, 31.0, only recognizes the PPAPI plugin.
Since you have an older version of Flash Player ActiveX for Internet Explorer, you should update that one as well to 18.0.0.209.
Maria
Hi vlad200204,
Maria
Hi Maria,
Ура! всё получилось.
everything is successful
Fantastic! Please do update Flash Player for Internet Explorer as well. The version you have installed, 17.0.0.169, is old and contains security vulnerabilities.
Maria
Она говорит: После скачанного экзешного файла в паке Загрузки (показать в папке) нажать правой КМ - Свойства - Разблокировать ! Теперь запустить установку.
Спасибо помогло!! _ _
