Is RH7 client compatible with X4 server ?
Guest
Jan 25, 2008 Jan 25, 2008
I am evaluating RH7 (client version) to see whether we should upgrade from X5. So far, I am very happy with the new features especially being able to open more than one topic at a time.
We create a combination of WebHelp Pro and HTML Help projects. Currently, we publish our WebHelp Pro projects to the X3 server version on a Windows 2000 operating system. I find that, when I open a project that I generated with RH7, the bookmarked text does not open. Also, some topics appear with the message: Page cannot be found. I'm assuming that the problem is that we are publishing a RH7 project to an X3 server version on a Windows 2000 operating system
We have the X4 server version, but we haven't installed it because of the Windows 2000 operating system. If we upgrade to Windows 2003, can we use RH7 (client version) with the X4 server version? Or, do we need to purchase RoboHelp Server 7?
Liz
554
Hi Liz. If you upgrade to RH7 (client) you must have the RH Server 7 to be able to publish your WebHelp Pro output. This is because of the unicode features added to RH7 (client) which previous version of RH Server will not be able to cope with.
Guest
Colum,
Thanks for your quick reply. I thought the documentation on RH7 (client) said that users do not need to upgrade the server version to RH7. I must have misunderstood.
Liz
Jan 28, 2008 Jan 28, 2008
If it did Liz I'd suggest it is wrong. Just like once you'd upgraded a RH6 project to RH7 you can not go back, because of the changes to the HTML code and the Unicode support, if you have RH7 only RH Server 7 can be used for WebHelp Pro output as only that version understands the underlying HTML and Unicode support. I did check this recently with Adobe before responding to a similar query from another user.
Guest
Colum,
Your explanation makes sense to me. Your reponses have been very helpful in understanding what we need to do for our upgrade to RH7.
Guest
Jan 30, 2008 Jan 30, 2008
I just want to clarify an assumption I made in this discussion.
While you need to upgrade to RH server 7 when you publish a WebHelp Pro project using RH7, you do not need to upgrade to a Windows 2003 operating system. RH Server 7 is compatible with a Windows 2000 operating system (according to Adobe's system requirements).
Liz
Jan 31, 2008 Jan 31, 2008
If you use a Windows 2000 server you need IIS version 5.0 but apart from that yes you are OK.
RoboHelp Documentation
Download Adobe RoboHelp
