I am trying to reload photoshop cs5 extended but i get an error message that a file may be missing and to download adobe support advisor which apparently is no longer used. I tried downloading CS5 on-line but that didn't work either. I don't see it in my software list to uninstall either. Not sure what to do--please help!
copy your disc contents to a desktop directory and retry installing. if you continue to see exit code 15,
check your install logs, Troubleshoot install issues with log files | CS5, CS5.5, CS6
attach a screenshot of the error message, if it's in english.
I ran the cleaner and thought it was working--I entered the prod key and then the dvd spun for awhile calculating installation size or something then stopped and said try again after displaying this error:
Exit Code: 15
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 0 error(s), 0 warning(s)
What now??
That worked--thanks!
you're welcome.
