25 Replies Latest reply on Aug 11, 2015 12:08 PM by Iamnotno6
    delorme gpx import not matching photos
      delorme event every 10 min while driving in BC/Yukon/Alaska
      i filter 1 day to keep it simple & export the gpx
      when i import the gpx, i see the track correctly in LR
      i select the photos for that day
      i check the timezone & the times overlap correctly
      when i click autotag all 22 photos end up at the end point
      if i hover on the track i only see the time (not date/time)
      the delorme app is mm/dd/yyyy and i use dd/mm/yyyy in LR
      could this be the issue?
      how would i fix it?
      i thought when i checked the timezone and saw the correct date/times all was OK?
