quote:
Originally posted by: rubo18
I got this working with SQL, but would still be interested in a possible CF workaround if it's out there, thanks :)
quote:
As you can see you have a few choices 🙂 ArraySum is an equally valid option. Though you may need a few more functions to convert the query column to an array.
<cfset columnTotal = ArraySum(ListToArray(ValueList(yourQuery.ColumnName)))>
Dan Bracuk,
I am curious. Why do you say that? I could not get arraysum(NameOfQuery["NameOfColumn"]); to work without the extra functions. That would be cool it if worked without them.
An error. The error message suggests CF cannot implicitly convert a coldfusion.sql.QueryColumn object to an array. Does it work for you?
[Table (rows 3 columns ColumnName): [ColumnName: coldfusion.sql.QueryColumn@14f8035] ] is not indexable by NameOfColumn
Thankyou everyone, I shall try some of these out! Although I found the SQL way was much easier than I anticipated it to be, so may just stick with that.
Umm, do I mark you all as giving the answer?? Sorry, don't know the proper etiquette here!
