All
Need help developing an uninstall and install batch file for network distribution of the latest version of Adobe Flash Player and is reboot required between the uninstall and install of the app. I've a ready download the install .msi file and uninstaller
thanks in advance to all for their assistance
Moving this thread to Installing Flash Player
Here is an excellent bat file i create, of course this is for the exe versions so you will have to change
Adobe Flash Updater - Browse /Clean Install at SourceForge.net
You will of course have to do the following as this is for the exe versions:
1) change anything with a /install i.e to a /qn for quiet
2) Be mindful of the updater service that is removed. You can of course remove that as well if need be
3) change any exe to your files.msi
4) make sure you get the uninstaller as well.
Also, you stated that a reboot is required, that is TOTALLY UNNECESSARY!
IF you kill the process that use flash it is not required. I have perfected this process.
I have not updated this bat in a min, so you might want to add into the taskkills the following lines:
taskkill.exe /im msiexec.exe /t /f
askkill.exe /im yahoo* /t /f
Best Regards
