Hi everyone. I am trying to create some drop down menus where if you do a selection in the first drop down menu, the second drop down menu will display. I have this working on 2 drop down menus,but the problem I'm having is if I choose something out of the first drop down menu and then change my mind and want to choose something else, the page goes blank. If I change it to something else in the first drop down, it should display all the results in drop down 2 according to what I chose in drop down 1. It does do this the first time if I choose the correct thing the first time, but if I try to change drop down 1, the page goes blank. What am I doing wrong? Here's the code I have:
<!--- store the selected Main_Group variable variable after the first select boxes submits itself --->
<cfif NOT isDefined("form.submit")>
<cfif isDefined('form.select_PinCount') AND form.select_PinCount NEQ "">
<cfset page.select_PinCount = form.select_PinCount>
</cfif>
<cfif isDefined('form.select_BodySize') AND form.select_BodySize NEQ "">
<cfset page.select_BodySize = form.select_BodySize>
</cfif>
<cfoutput>
<form method="post" action="email_code_test9.cfm">
<!--- query DB for the first drop down list --->
<cfquery name="get_PinCount" datasource="#application.datasource#">
SELECT DISTINCT Pin_Count
FROM BGA
ORDER BY Pin_Count
</cfquery>
<!--- first drop down list --->
<!--- NOTICE the onChange javascript event in the select tag, this is what submits the form after the first selection --->
<select name="select_PinCount" required="yes" onchange="this.form.submit()">
<option value="">Select Pin Count</option>
<!--- dynamically populate the first drop down list based on the get_PinCount query --->
<!--- NOTICE the CFIF within the option tag, this says, if the first selection has been made, display the chosen option when the page reloads --->
<cfloop query="get_PinCount">
<option value="#Pin_Count#" <cfif isDefined('form.select_PinCount')><cfif form.select_PinCount eq Pin_Count>selected</cfif></cfif>>#Pin_Count#</option>
</cfloop>
</select>
<br><br>
<!--- if the first selection has been made, display the second drop down list with the appropriate results --->
<cfif isDefined('page.select_PinCount')>
<!--- query DB for second drop down list, based on the selected item from the first list --->
<cfquery name="get_BodySize" datasource="#application.datasource#">
SELECT DISTINCT Body_Size_mm
FROM BGA
WHERE Pin_Count = #select_PinCount#
ORDER BY Body_Size_mm
</cfquery>
<!--- second drop down list --->
<select name="select_BodySize" required="yes" onchange="this.form.submit()">
<option value="">Select Body Size</option>
<!--- dynamically populate the second drop down list based on the get_BodySize query --->
<cfloop query="get_BodySize">
<option value="#Body_Size_mm#" <cfif isDefined('form.select_BodySize')><cfif form.select_BodySize eq Body_Size_mm>selected</cfif></cfif>>#Body_Size_mm#</option>
</cfloop>
</select>
<input type="Hidden" name="Submit" value="Submit">
</cfif>
<br><br>
</form>
</cfoutput>
</cfif>
The link to this is here: https://www.ironwoodelectronics.com/catalog/Package_Specs/email_code_test9.cfm
Thanks.
Andy
Have something to add?
