pass query to oracle
Advisor ,
Aug 24, 2015 Aug 24, 2015
HI All,
How can I pass a query to oracle using cfstoredprod?
Try this:
<cfstoredproc datasource="#application.dsn#" procedure="#importTable#">
  <cfprocparam type="in" cfsqltype="cf_sql_refcursor"  value="#myQuery#">
</cfstoredproc>
Oracle code:
Procedure importTable ( v_table IN SYS_REFCURSOR) is
Getting error: [Oracle JDBC Driver]Unable to determine the type of the specified object.
Any ideas?
Thanks in advanced.
616
LEGEND , Aug 26, 2015 Aug 26, 2015
Get your records and put them into a query object (if they are not already), call it getRecs, and:
<cfquery name="bulkInsert" datasource="#application.yourDSN#">
INSERT ALL
   <cfoutput query="getRecs">
      INTO schema.tableName(columnA, columnB, columnC, etc)
      VALUES (<cfqueryparam value="#getRecs.column1#" />,<cfqueryparam value="#getRecs.column2#" />,<cfqueryparam value="#getRecs.column3#" />,<cfqueryparam value="#getRecs.column4#" />)
   </cfoutput>
   SELECT * FROM DUAL
</cfquery>
Why are you passing a query to a stored procedure?  Stored procedures are great for _running_ queries, but the query should already exist in the stored procedure.  You can pass variables in the cfprocparam for dynamic content.
V/r,
^_^
Advisor ,
Thanks for your reply and help.
I am trying to do a bulk import of 100K records into Oracle.
Doing a cfquery with a loop insert takes too long.
Do you know a better way of doing bulk import?
Best,
INSERT ALL
   </cfoutput>
   SELECT * FROM DUAL
</cfquery>
You must include the "SELECT * FROM DUAL" after the output loop.  This will make one connection to your database (Oracle), insert all the rows, and disconnect.  Place it within a CFTRANSACTION tag to make sure they are all inserted, or all rolled back.
HTH,
^_^
Advisor ,
Sep 02, 2015 Sep 02, 2015
Thanks for you reply and help!
Best,
Documentation
