I have an input type checkbox as shown:
<input type="checkbox"
id="compenPercent"
name="compenPercent" <cfif
rsAgreement.Percentage EQ
1>checked</cfif>>Percentage
id="compenlumpsum"
name="compenlumpsum" <cfif
rsAgreement.LumpSum EQ
1>checked</cfif>>Lump Sum
The table fields which is used to store these values are
declared as bit. I would like to have the value=1 when the user
checks the box.
In .cfc, these form fields are: I tried using type=Boolean
also
<cffunction name="createAgreement"
access="remote"
returntype="string" hint="Add
agreement.>
<cfargument name="IsCompenPercent"
type="numeric" required="yes"
default="0">
<cfargument name="IsCompenLumpSum"
default="0">
INSERT INTO Agreements
(Percentage,
LumpSum)
VALUES
(<cfqueryparam
value="#arguments.IsCompenPercent#"
cfsqltype="cf_sql_bit">,
<cfqueryparam
value="#arguments.IsCompenLumpSum#"
cfsqltype="cf_sql_bit">)
If I checked the box and save it, it gives an error:
The argument INTPERCENTVALUE passed to function
createAgreement() is not of type numeric.
How do I passed a value 1 from a checbox input type?
Also how do I handle a Null value from an input type=text and
the field is integer. This seems to be a problem for integer but
not on string. For strings, there is no problem if it's NULL.
Thanks for any help.
