How could I loop through all possible rearrangement combinations of these 8 characters? LLLMMRRR
I need it to be output with trace command and numbered if possible.
is each L a different character? ie, if you only had LLL would there be one or 6 displays?
I have 3 L's 2 M's and 3 R's in one arrangement like the one you see above. I want them to be rearranged in deferent order and I need to see all possible combination in the output through trace command.
again, are different combinations that look the same, different? if so, you'll see LLLMMRRR listed 72 times.
I want to output all possible combination since I have to go through each one by one.
var i:int;
var s:String = 'LLLMMRRR';
var permA:Array = [];
permF(s,'');
trace(permA);
function permF(s: String, pre: String): void {
if(s.length < 1){
permA.push(pre);
} else {
for(i = 0; i < s.length; i++){
permF(s.substr(0, i) + s.substr(i + 1), pre + s.charAt(i));
p.s. if you want combinations (i never got an answer from you that i could understand), sort permA and loop through its elements checking for duplicates:
function removeDupsF(a:Array):Array{
a.sort();
for(var j:int=a.length-1;j>0;j--){
if(a
a.splice(j,1);
return a;
I only get one output LLLMMRRR
that's interesting. the problem is i.
use:
//var i:int; // commented out
permF(s,'');
trace(permA);
if(s.length < 1){
permA.push(pre);
} else {
for(var i:int = 0; i < s.length; i++){ // <-i is local of permF and retains its value during during function calls
and please mark correct and helpful responses. i see you still have not done that in your collision thread.
This one worked...ish, I got all the possible combinations (I think) but
they were multiplied by 72. so I got 72 LLLMMRRR and then I got
72 LLLMRMRR... and so on and so forth.
