7 Replies Latest reply: Feb 4, 2008 2:29 PM by Newsgroup_User RSS
    onMouseOver image to popup window
    PBGV Community Member
      I recently upgraded from Dreamweaver 8 to CS3. Previously, using behaviors, I was able to have a pop up window appear with a larger version of a thumbnail image. I have spent hours (cannot remember exactly what I did before) trying to recreate this in CS3...no luck. Have searched everything in site and cannot find instruction. Following is the page that does work and the code. Can you help? Veronica
      http://www.topofthebaypetlodge.com/showdogs.html
      <a href="javascript:;" onmouseover="MM_showHideLayers('Layer3','','show')" onmouseout="MM_showHideLayers('Layer3','','hide')"><img src="images/show dogs/1-fairchild-thumb.jpg" alt="Fairchild" name="Fairchild" width="120" height="120" vspace="2" border="0" id="Fairchild" /></a><br />
      <a href="javascript:;" onmouseover="MM_showHideLayers('Layer4','','show')" onmouseout="MM_showHideLayers('Layer4','','hide')"><img src="images/show dogs/2-fairchild-thumb.jpg" alt="Fairchild2" name="Fairchild2" width="120" height="120" vspace="2" border="0" id="Fairchild2" /></a><br />
        • 1. Re: onMouseOver image to popup window
          Newsgroup_User Community Member
          I checked your url in Firefox and IE7 and the behaviors seem to be
          working just fine.
          E. Michael Brandt
          www.divahtml.com
          www.divahtml.com/products/scripts_dreamweaver_extensions.php
          Standards-compliant scripts and Dreamweaver Extensions
          www.valleywebdesigns.com/vwd_Vdw.asp
          JustSo PictureWindow
          JustSo PhotoAlbum, et alia
          • 2. Re: onMouseOver image to popup window
            The page I listed was one I had created in Dreamweaver 8. Now I am working on a different page in Dreamweaver CS3 and cannot create the same effect. When I did the first one, I remember thinking how easy; however, cannot remember how I managed to select a thumbnail image and attach behaviors to create this same effect. Am thinking something has changed in CS3 and notice "deprecated" in behavior panel with grayed out hide/show pop up menu. Can you help or lead me to instructions? Thanks, v
            • 3. Re: onMouseOver image to popup window
              Don't confuse pop-up menus with popup windows. The behavior you want is
              still there - OpenBrowser Window. But Michael's divaPop may be a better
              choice -
              http://divaHTML.com
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              "PBGV" <webforumsuser@macromedia.com> wrote in message
              news:fo7msp$4ii$1@forums.macromedia.com...
              > working on
              > When I
              > how I
              > same
              > effect. Am thinking something has changed in CS3 and notice 'deprecated'
              > in
              > lead me
              • 4. Re: onMouseOver image to popup window
                I will look into Michael's divaPop. The open browser window opens a 2nd browser window rather than a layer as in my original page. Thanks for your suggestion, v
                • 5. Re: onMouseOver image to popup window
                  Oh - in that case you just want the Show/Hide Elements behavior.
                  news:fo7nok$5c1$1@forums.macromedia.com...
                  >suggestion, v
                  • 6. Re: onMouseOver image to popup window
                    It was meant to be simple that anyone can fall over:) I think my problem was I do not remember what actually worked with the show/hide behavior. I thought I had selected the img tag and seem to remember adding a div around existing thumbnail, then what behavior do I choose? I think if if knew that step, then I could show or hide the behavior upon mouseover....v
                    • 7. Re: onMouseOver image to popup window
                      Add a link around the image. Select the image, and enter "javascript:;"
                      (that's colon semicolon) in the Link field of the Property inspector. Then
                      apply the behavior to the <a> tag.
                      news:fo81g1$fpe$1@forums.macromedia.com...
                      > was I
                      > thought I
                      > then
