RoboHelp 6 and 7 when used on Windows 2003.
Participant ,
Feb 05, 2008 Feb 05, 2008
Hi:
I read that the latest version of RoboHelp (RH7) does not work on Windows 2003. See http://www.adobe.com/products/robohelp/productinfo/systemreqs/ for RH7's OS requirements. RH7 is certified for Vista, XP and 2000; but not 2003. Isn't that surprising? Does anyone know what are the issues with using Windows 2003 and RH7?
Surprisingly, the online help for RH6 says RH6 is certified on OS Windows 2000 SP4 and later which means Windows 2003 should be supported. In that case, why should a later version (RH7) drop support for it?
I ask because we are facing several performance issues using RH6 on Windows 2003 (we just upgraded from Windows 2000). It takes a long time to do just about anything in WebHelp (for RH6). Our project is huge and uses Visual SourceSafe for version control. We didn't have any such problems using RH6 on Windows 2000.
Kutra
479
LEGEND , Feb 05, 2008 Feb 05, 2008
Kutra. Do you mean Windows Server 2003? If so, you can't use RH6 or any other version from a server.
Windows 2003 is a server operating system. RH7 is not designed to work from a server.
There must be a time lag out there in cyberspace. I trod on your toes 17 minutes ago Peter and only just realised it
Participant ,
Thanks guys, for your responses. It was Windows Server 2003.
I'm a little confused. We recently purchased RoboHelp 7 installed (on my computer with XP) and RoboHelp 7 Server that is running on Windows Server 2003 R2. Are you saying that I can't run it on this server? I am getting errors when I try to publish, so not sure if it is due to this.
It's just RH7 that you use to create the topics that cannot be run on a server. RoboHelp 7 Server must be run on a server.
RoboHelp Documentation
Download Adobe RoboHelp
