CF8 Use of clientCert and cfhttp
Feb 05, 2008 Feb 05, 2008
Dears,
In coldfusion 8, we are trying to implement a web service call in secured mode (use of ssl and client certificate).
we used therefore new elements clientCert and clientCertPassword into cfhttp command.
we received a Connection Failure as a result (coldfusion side).
At web server of producer side (Apache), we receive an error HTTP 400:
172.21.160.124 - - [04/Feb/2008:13:18:23 +0100] GET / 400 472 - - -
Any idea / hint would be welcome ;)
code page is attached
Advanced techniques
2.4K
Feb 06, 2008 Feb 06, 2008
Another important element:
the certificate .p12 is not a certificate trusted by a Certificate Authority like Verisign.
It is one that we generated at our side.
Is there maybe a specific configuration to do in this case in ColdFusion or in our machine (Windows 2003 Server)?
Feb 18, 2008 Feb 18, 2008
Hi
I am actually running into the same issue her eon my end with a p12 cert.. Have you found anything else? I get the same connection error as well. Here's my code.. I tried both sending garble to the service and actual soap messages.
<CFSAVECONTENT variable="myXML">
hello
</CFSAVECONTENT>
<CFHTTP
method="post"
url="https://198.136.211.18/axis/services/TPGSecureLink"
port="8448"
clientCert = "c:\inetpub\wwwroot\adirondack3.p12"
clientCertPassword = "xxxxx"
result="getout">
<CFHTTPPARAM type="header" name="SOAPAction" value="">
<CFHTTPPARAM type="xml" value="#myXML#">
</CFHTTP>
<CFDUMP var="#getout#">
Feb 19, 2008 Feb 19, 2008
yes we went further. But this is not so easy.
Explanation:
Before an SSL connection can be established with CFHTTP to a server the certificate of that server needs to be imported as a trusted certificate in the ColdFusion truststore with the keytool command. The command to do so is:
keytool -import -trustcacerts -keystore cacerts -storepass <password> -noprompt -alias <alias> -file <certfile>
If you use another CA certificate authority, then you also have to import the CA into the ColdFusion truststore.
Before a client certificate can be used it needs to be in a specific format, pkcs. Of course this client certificate must contain the private key.
You also have to import the client certificate into the Windows Certificate Store (if you run under a windows desktop/server).
In your ColdFusion cfhttp tag, use this .pkcs certificate file.
Tell me if it works like this 🙂
Documentation
