quote:
Originally posted by: mike95060
Thanks, jjpijpker.
I use RealPlayer all the time so I am hoping someone can figure how to make Flashplayer work, because I will have to give up using Flashplayer on Firefox and keep RealPlayer (even if RealPlayer IS causing Flashplayer to misbehave on my computer). I'm glad that at this point I can use Flashplayer on IE.
quote:
Originally posted by: woostie
Shancan Wrote: "FlashPlayer 9.0.115.0 is causing all sorts of playback problems; doesn't matter which browser or platform. Try an earlier version of Flashplayer like 9.0.47.0. and see if that helps. "
Finally an answer that works. Runnin 9.0.47.0 now and it seems to be ok.
I got the version 9.0.47.0 at the "Archived Flash Players available for testing purposes" page:
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14266&sliceId=2
Extracted the .47 version and (after uninstalling all flash) ran the windows installer. Seems to work fine in Firefox now.
I've chaged settings to keep Flash from updating unless I okay it Change your flash settings by means of the following page:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html
Shancan wrote:
"I don't know why Adobe still has the latest FlashPlayer 9.0.115.0 up there...it's like Free Gas that causes your car to choke and not run right."
Agreed, except it's only cause trouble for me with Firefox, which is about 1/5 of the market (about a third in Europe), so it seems like it would be thoroughly tested in Firefox.
Anyway thanks ShanCan. I won't upgrade Flash until absolutely necessary unless they explicitly say they've fixed this issue.
Oh, there is probably some security issue with version 9.0.47.0, so use it at your own risk.
quote:
Originally posted by: tcolberg
I have the exact same issue and haven't seen the problem addressed anywhere else. It only started after I upgraded to the latest version a few days ago. I have RealPlayer on the system, but do not use it. WinXP, Firefox 2.0.0.11. I suppose I'll try downgrading.
