Attempting to use the "Create PDF for Review", however, the Enable commenting in Adobe Reader is greyed out. Adobe Reader X1 and Adobe Acrobat DC is installed, are either compatible?
Sep 02, 2015 Sep 02, 2015
366
In the Create PDF for Review window, do you have "Enable commenting in Adobe Reader" marked?  I have RH10 and can add comments using Adobe Reader XI.
It is greyed out, I am unable to select.  The "Send for shared review" is also grey out.
Contributor ,
Oh jeepers... I misread your post and thought you meant that the commenting feature in Adobe Reader was greyed out.  (I accidentally had logged in with my personal Adobe ID, so that's me as "inky-fingers".) Sorry about that!!
Just an FYI, I have Adobe Reader XI and Adobe XI Pro both installed on my system (and RH10).
Best Practices says that’s a “bad idea”
I forgot to mention, I have RH11
You don’t need Reader installed on the same machine that has Acrobat in place. Not good to have both competing with each other.
I will uninstall reader.
I uninstalled Adobe Reader XI, still greyed out
Do you have the full Distiller version?
yes
In what order did RH and Acrobat get installed?
RH and then Acrobat
Can you create a PDF by right-clicking on the topic in the Project Manager and doing the "Create PDF for Review" option? Or is that option not active at all? If that's the case, then I think RH thinks you don't have a PDF creator installed.
it's not available
Sep 03, 2015 Sep 03, 2015
Did you install Acrobat as part of the Technical Communication Suite or as a separate application? I believe the option is only enabled when Acrobat is installed as part of the suite.
RoboHelp Documentation
Download Adobe RoboHelp
