I'm getting the same Exception, using InDesign:
Process: Adobe InDesign CC 2015 [3550] Path: /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015 Identifier: com.adobe.InDesign Version: 11.1.0.122 (11100) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: Adobe InDesign CC 2015 [3550] User ID: 393393107
Date/Time: 2015-09-02 14:17:02.577 -0700 OS Version: Mac OS X 10.10.3 (14D2134) Report Version: 11 Anonymous UUID: 7EA882AA-67F0-9B9E-74F7-6FB9407DCF94 Time Awake Since Boot: 7000 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x00006188003be758
Any ideas?
You'll need to provide more information about what is happening when you crash? Was InDesign working before? Has anything changed in your system?
I'll forward this to the InDesign forum where some users may be able to interpret your report.
Thanks, Steve. It was working just fine before I started developing a new document, developing a template as I go. Nothing has changed in my system -- no Adobe updates (Flash or otherwise), no Mac updates that I know of, nothing new. I sent a co-worker a copy of the file, and it also made InDesign crash on her system, but I don't know what caused the crash from her end.
It happens when I'm typing, when I copy and paste text or graphics, when I add text that flows into the next text box, when I tag some text as a particular paragraph style... probably other times, as well, but I have forgotten all of the times it has given me errors.
I am new to InDesign, so it's incredibly frustrating because I don't know if I accidentally tried to make it do something it's not supposed to do, or if there is something wrong with [my system, my template, my styles, my brain].
I can attach the entire error report, if that's helpful, or send you the file I'm working on... What would be most useful?
Are you the same person who posted the crash report (please post reports on pastebin.com, not here, and provide a link)? If so, you need to run the latest patch for InDesign CS6, then try again. If not, post the crash report and give us the link.
No, I haven't posted a crash report. But here it is!
Where is the latest patch for InDesign CS6? (Sorry, I'm new to this forum and to InDesign!)
Help > Updates...
Huh. It looks like I already have the most up-to-date updates. I'm not given the option to update InDesign.
AND it just happened again, this time while trying to add space after a particular paragraph style... Same Exception Code and Type.
Please put the crash report on pastebin.com and give us a link.
And here is the one that just happened, when I was copy/pasting an image from the same document into a new location. Same Exception type and code:
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x00007f94198039e8 |
I branched this into its own topic. Your crash report indicates this is text related. My guess would be either a bad font or a corrupt style.
Could be... but I uninstalled InDesign, re-installed it, and started over again, with a brand-new file today -- and it happened again. The only changes or additions I have made to the styles is to change the fonts, sizes, and tabs.
I opened a ticket with our IT department, maybe they can help.
Based on the crash report I think this solution might work for you InDesign CC 2015.1 crashes while working on text
Thank you! I just tried the solution... I'll check in later after working on my files for a while to make sure it's fixed!
So far, so good. I only had one crash all afternoon. I hesitate to say that it's fixed... but I'm cautiously optimistic. Thank you all!
