Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
The public Key certifcate retrieved from server (------) is not recognized as originating from
Avatar
Level 2
Hi there,
We are using SSL for adminui and everything is working fine. I tried to use SSL for workbench and changed the profile setting in the connection to use protocol "Simple Object Access Protocol (SOAP/HTTs) with Server Port Number:8443 and I did add the certificate to the store per documentation and am still getting the error "The public key certificate retrieved from server (--------) is not recognized as originating from a trusted source. Check with your system administrator for instructions on configuring Workbench to accept this certificate.
Workbench ES3
Avatar
Level 2
I did that doc word for word (Even several times) and workbench is not allowing me to connect from my workstation but it works using HTTPS on the server itself.
Avatar
Employee Advisor
Point to be noted : Ensure that you connect to HTTPS by using the name that is specified in the certificate. This name is typically the fully qualified host name.
Avatar
Level 2
The name specified in the cert is the host name only and not the full qualified domain name. Does it really have to be the FQDN instead.?
Avatar
Employee Advisor
In server settings(Workbench), you should provide the hostname as there in your certificate(i.e. hostname + domain).
Avatar
Level 2
Everything matches. Cert is hostname and the server settings(Workbench) is hostname as well.
Avatar
Employee Advisor
Check whether certificate has been imported inside cacerts keystore successfully, use keytool -list -keystore <Path to cacerts> | more
Avatar
Level 2
it looks like it did.
Keystore type: JKS
Keystore provider: SUN
Your keystore contains 1 entry
ServerName, Jun 5, 2013, trustedCertEntry,
Certificate fingerprint (MD5): (Entry)
Avatar
Employee Advisor
Could u plz confirm the path to cacerts ? Bcz there are many trusted certificate already present by default but u have only one entry !!
Avatar
Level 2
E:\Program Files (x86)\Adobe LiveCycle Workbench ES3\workbench\jre\lib\security
Avatar
Level 2
Does it matter whether the certifcate is for HOST name and the FQDN?
Avatar
Level 2
I already did that and still doesn't work. Thanks
Avatar
Level 1
You can try the below steps if you are using jBoss app server.
1.Open the secured adminui url (https://localhost:8443/adminui/) in the browser (ie explorer) .
2.It will give you the certificate error. Import that certificate by going to detail tab -> copy to file-> next-> select option DER encoded binary x.509 .cer
3. Save the above cert file to your local machine where workbench is installed.
4.Now run the below command
5.keytool -import -file “path of the above cert file on your machine including the cert name" -keystore "C:\Program Files (x86)\Adobe LiveCycle Workbench ES4\workbench\jre\lib\security\cacerts"
6.it will ask for password , which is changeit
7.it will ask if you trust this certificate , type Y then enter
8.Now your secured https certificate is imported to the cacerts file present in the security folder of workbench.
9.Restart the workbench, and before logging , configure the workbench login portal by providing below details
a)Hostname: localhost
b)Protocol : select the secured one (soap/https)
c)Port number will be : 8443 (for jBoss)
10. Try logging.
Avatar
Level 2
I know this is old, but I have tried all the steps in this thread, plus rebooting my workstation, and I am having the same problem. Has anyone found a solution to this problem?
Avatar
Level 2
In case anyone ever runs into this problem in the future, the solution for me was to delete the jre folder within the workbench folder, and replace it with the latest jre downloaded straight from Oracle. Then I imported the certificate into the cacerts file. Originally I had installed java through the workbench interface, but it seems like it may have been using an old version. Hope this helps someone.
Avatar
Level 1
Sorry to bump this old thread, but I am also  having this issue.   I have:
- followed the steps to import the certificate into the cacerts used by workbench
- ensured i used the FQDN in workbench properties that match certificate
- restarted system
- no luck
- replaced entire jre folder in workbench path as suggested above
- re-imported the certs
-restarted system
- still no luck
Browser access over https works just fine.   I'm stuck here.   Any other ideas from anyone?
Avatar
Level 1
Did you obtain a solution to the issue regarding the public key certificate and launching Workbench as https.  I am also getting the same error and have tried all steps on the forum.
