Hello All,
Firstly you might tell me to bugger off since im using
Bluedragon and not CF (CF 7 would get rid of my problem) so any how
im trying to create a work around.
OK here goes:
I have a CFCHART (all works great)
The parameter in ;
CFCHARTDATA item='data label here'
always renders as horizontal on the data labels, in CF 7 you
can use a style sheet to customise this attribute to render
vertically I believe the value is something like;
labelstyle isHideOverlapped TRUE orientation=Horizontal
Ok but I dont have this luxory in Bluedragon, but I have
noticed I can get vertical text if I preset a variable like below.
CFSET dataname = 'JOE'
(if I use this as my item parameter
CFCHARTDATA item= dataname
I get horizontal text as you would exspect.
CFSET dataname = '
J
O
E
If I use the dataname variable set like above I get nice
Vertical Text.
So I thought Im on a roll here, I have been trying to work
out some loop to just format my datanames like above but I cant
work it out. any ideas.
Or my other metod would be to somehow set the dataname
variable against a CSS stlye.
I can set a stlye up in the header and then Is it possible to
apply that class stlye against a variable?
these are the two work arounds im trying but Im not having
much success.
Any one got any ideas pleaase
Kind Regards Guy
Sorry messed up attaching code etc, been a long day so far.
