Found it at the bottom of the RoboHelp download page...
http://www.adobe.com/support/robohelp/downloads.html
I was thinking it might help a problem I'm having with RH7.
When you load the application and put in the Serial Number the
application will run. However, if you close the application and try
to run it again it hangs while trying to open...says initializing
version control and then never opens. I have a coworker have the
same thing happen...Can't get it to work again unless you do a
reinstall and then the same thing happens over again! I'm
desperate!!!
RoboHelp Version 7
RoboHelp Classic
RHC7SR1.EXE is a Service Release for all RoboHelp Office,
RoboHelp Classic and RoboHelp Classic 7.0 users. It is a standard
application that finds the install directory for RoboHelp and
updates the necessary files via a self-extracting executable file.
RoboHelp HTML Edition
RHH7SR1.EXE is a Service Release for all RoboHelp Office,
RoboHelp Classic and RoboHelp HTML Edition 7 users. It is a
standard application that finds the install directory for RoboHelp
and updates the necessary files via a self-extracting executable
file.
