I just paid for a annual subscription of Captivate 9, and downloaded it into a Windows 7 enviroment. I thought the install went OK. Then clicked on the Icon, the application comes up, and asks me to select a project. Within sixty seconds, it crashes, regardless of what I do.
I have chatted on line with the Adobe support-Waist of time: We ran some clean scripts, turned off fire wall, erased fonts, sent logs- nothing worked.
I uninstalled, and reinstalled. Same error. Anyone have ideas?
When it crashes, does it post any other information?
Where are your user folders? Are they perhaps on a network location?
Do you have ample free space on your hard drive?
Cheers.. Rick
Thanks for responding Rick.
No messages are posted.
No, the files are all under Program Files on the C:/ drive. Lots of disk
space. All good ideas.
Out of curiosity, does anything change if you disconnect from the web and try starting it again?
Just tried it, nope same problem- just comes up, and then right back down.
Are any other applications running at the moment? It sounds like something else may be running that Captivate doesn't like for whatever reason.
Perhaps try temporarily disabling any antivirus or antimalware apps?
Cheers... Rick
Crash issue with Captivate 9 has been resolved now. Please follow the steps below to Activate the Captivate 9 license:
Step 1:
Step 2:
These steps should resolve the issue. Please feel free to right me back in case you face any issue.
Mayank
I had the same issue and signing out and signing in again totally solved the problem. Thank you.
