Hello fellow RH Gurus:
I wanted to check in with you all to see if any of you had
knowledge into whether or not we could make an imported PDF file
"searchable". That is Robohelp allows you to import pdf files into
projects, but once they are imported (during the import process),
you must import them as JPEG. Hence, the imported PDF files TEXT is
not searchable. Is there any way around this?
I just wanted key words within the PDF file to show up in the
search when a user looks for it. Currently, it does not.
Any help you can provide is greatly appreciated!
Best Regards!
FTBGUY
