quote:
Originally posted by: Captiv8r
All that dialog is telling you is this:
You have created links to other content. This content may be a simple URL, Word Document, PDF, etc. Captivate is not going to do anything to ensure those files exist when you copy the Captivate files to wherever you will run them from. So be sure you take care to copy the linked content to the locations where the Captivate output will expect to find them. Otherwise, the links are going to fail!
Hopefully this was helpful... Rick
Hi ptrader and welcome to our community
You are describing absolute links. I'm guessing you browsed to the PDF and linked that way? Normally you want to simply type the file name of the PDF into the area where you establish the link. Once you do this, the link becomes relative and should find the .PDF with no issue.
quote:
However, you do bring up another point. Sometimes we see that PDF and Word content refuse to open from links. In these cases, I normally advise folks to create a MenuBuilder output that is essentially invisible. Make it as small as possible and create the links (same issues apply with relative VS absolute links here) then drop that published MenuBuilder .SWF output into a Captivate slide over text or button image the user will click to open the file.
