Hi ljlove3
Unfortunately there is no single “click a button and
poof! it's converted” type of solution here. What you would
probably need to do is to first rename the original simulation.
(for safekeeping) Then open the Demo and click File * Save As to
create a copy. Then edit the copy to remove the Demo bits and add
in the Simulation bits. Turning off the mouse for the sim is easy
enough. Just select all the slides with mouse movement and click
the Slide menu. Then drop over or down to the “show
mouse” option and DE-select the mouse. From there, you would
add in Click Boxes and whatnot to make it a simulation.
Hopefully something here was of value to you... Rick
