I had installed the adobe digital software and the following messsage is showing up:
Fehler beim Abrufen der Lizenz. Lizenzserver-Kommunikationsfehler:
E_ACT_NOT_READY
I have tried to re-authorized my computer - but it doesn't work!!
Thanks for your help
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
Now again AUTHORIZE ADE
Help-> authorize computer.
Error will be fixed !!
I've got the same problem, using MacBookPro OS X 10.10.3
Deauthorizing dos not work either. So there is no way to get further to authorize ADE
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Mac:
1. Go-> Go to folder.
Go to folder dialog will appear.
2. Type ~/Library/Application Support/Adobe/Digital Editions
drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
I've a iMac and I try to delete "Activation.dat" but there is no folder "~/Library/Application Support/Adobe/Digital Editions". Can anybody help?
