When generating RH webhelp pro as an output, I need the
default index web page to be named according to naming conventions
set by the developers. How do I do that? This is NOT about setting
the default topic.
Note from eng:
How do I get RoboHelp to change the auto-generated
frameset’s filenname? Right now it is outputting as
<Project Name>.htm, but the engineering team is asking that
it create a standard index name of index.html, so that they link to
the help like <a href=”/help/”> instead of having
to link like <a href=”/help/<project
name>.htm”>
It's whatever you define in the first field of the first page
of the wizard. RH creates a default but you can change it and it
will stick until you change it again.
Hi....When generating RH WebHelp Pro, I am having the same
issue. Even when I enter the following in the Output Folder/Start
Page field: C:\FREIGHT\mas90200\index.htm, RH is generating the
Webhelp directory like this:
C:\freight\mas90200\index.htm\SageMAS90_200.htm.
Even if I change the "first field", Project Name to
index.htm, it still won't generate "index.htm".....still generates
SageMAS90_200.htm.
