Hope someone might have an answer for this. I am trying to
help out a friend that I wrote some CF for a while back but now
they are moving to a new server and SQL server configuration. I am
not sure of the specifics so if you need more to answer this
question I can ask him and get you more information.
Here is the error message:
The following information is meant for the website developer
for debugging purposes.
Error Occurred While Processing Request
Error Executing Database Query.
[Macromedia][SQLServer JDBC Driver][SQLServer]The multi-part
identifier "System.Web.HttpCookie" could not be bound.
Resources:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debugging Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1;
.NET CLR 2.0.50727; .NET CLR 1.1.4322; .NET CLR 1.0.3705;
InfoPath.2; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022)
Remote Address 12.198.59.2
Referrer
Date/Time 11-Feb-08 08:57 AM
Any help would be greatly appreciated!
