Other topics in the project open at the top. Is there a setting I missed?
Hi there
Is there a setting you missed?
Well, quite possibly. After all, there are things you missed when you posted!
For example:
How is the topic being opened? From the TOC? From the Index? From the Search? From a Hyperlink in another topic? From a button of some sort?
If it's from the search, the topic is likely scrolling to reveal the area where the search term was found. If it's from the TOC, the Index or a Hyperlink, it's likely that the link from these areas is pointing to a Named Anchor (Bookmark) in the topic.
Cheers... Rick
Thanks for the quick reply and sorry the post was so lacking in needed information. A bit of frustration / desperation leaking out I suppose. I was opening the topic from the TOC (published project-issue identified during QA testing). I looked in the HTML view and did not ‘see’ a bookmark in the area.
Where would I look to verify that the ‘pointing to’ code is correct? Hope that question makes sense. I’m new to RoboHelp and not sure of all the language I should use.
Thanks, Mary
Mary Coffee
Lead Technical Writer
Topics open when users click a link somewhere. What is it you are clicking that opens this topic half way through?
I’m clicking the topic from the generated project’s TOC. I found some information about a bookmark in the middle of page but when I looked in the HTML view I couldn’t find a bookmark??? Any other idea?
Thanks for all you help.
Mary Coffee
Ordinarily I would say the TOC must be configured to link to the bookmark but you there isn't one in HTML. That does not ring true and you say you have found some information in the middle of the page. What information?
May post an image and some of the code. You will need to do that via the web interface, not by email.
What’s the Design view show (don’t forget to turn on the code indicators or it’s going to look like all text and no other interesting stuff)
Hello again
Peter and Jeff have both intimated that we need to see something about how the TOC is configured.
Okay, let's try this. From the TOC entry that causes the page to open in the middle, right-click it and look at properties. Copy all the text in the field at the bottom of the dialog and paste it here for us to see.
Cheers... Rick
I have right clicked and opened Properties for the TOC entry for the ‘problem’ topic. There’s a long list of items in the Page Destination -Existing Topics - Top Level Folder. I can only copy one item at a time. But I did view each item and saw something that looked out of place. I deleted it and now the link from the TOC works properly.
Thanks so much for your help. Since I’m so new to RoboHelp, I’ll probably be calling on your help again ☺
Mary Coffee
LOL, consider this to be your free RoboHelp "microlesson" of the day.
That long list of "Existing Topics" is a list of all the topics available to link to within whatever folder is shown. These are potential targets. From this dialog, you are able to choose any of them to point the link to.
That's why I asked you to look at the field at the bottom of the dialog. That area lists the path and link that is currently set for that TOC entry.
There is likely no way to tell now that you have "fixed" things. But I'd bet my bottom dollar that there is a bookmark in the topic that was previously set as the link destination and what would have proven that out would have been the text you would have copied.
Cheers... Rick
Yes, that was the link I deleted. I’m sorry if my explanation was clumsy. I did exactly what you said to do and that fixed it. ☺
[signature removed by moderator]
Hi
I have a similar issue - but I can't seem to fix it as above.
My document has a long toc - and we are using Robohelp, Multiscreen output for sharepoint.
When we click on a menu item in the navigation bar, first it moves up to the top of the new page (near the title), and then it moves back down to align the screen with the navigation toc item - so the new page is displayed half way down. Sorry, can't screencapture it due to business requirements.
We would like the screen to display top of the new page, and not align itself with the menu item. This happens to all of the pages (so assume it might do with a setting)
ToC is automatically created.
Any ideas on changing it?
I know you can't share a screen capture of what's happening, but what about one where you have right-clicked the TOC element and revealed the properties?
Cheers... Rick
I was using Robohelp 11, but it seems to be working ok in Robohelp 15. Just tried it.
Simone
