I have a 64 bit OS and 32 bit office and want to know if Adobe Presenter 11 is compatible. Thank you.
Yes, It is compatible with 64bit OS and 32bit Office.
The installer will take care of this and install the appropriate Presenter.
Alpi Agarwal
Adobe Presenter Engineering Team
Alpi Agarwal
Thank you very much Alpi Agarwal for this answer. It has helped a lot. I have one more question regarding Presenter 11 and compatibility. Can Presenter 11 be used to work on files created in Presenter 7 and Presenter 9 files? I know the files in Presenter 7 and 9 were created or authored with an XML 4 library and Adobe Presenter 11 uses an XML 6 library. I just want to make sure Adobe Presenter 11 is backwards compatible with the older versions of MSXML as a majority the classes created used MSXML 4 and Presenter 11 requires MSXML 6.
Thank you for your time.
