I have mac book pro with osx 10.10.5 version. I am trying to install the Standard Coldfusion Builder 3 but after next it display the following error:
Mac OS X platform should be 10.6
To Install Standard Adobe ColdFusion Builder 3, You need Mac OS X version 10.8.
I have the java version displat after java -version command:
java version "1.8.0_31"
Java(TM) SE Runtime Environment (build 1.8.0_31-b15)
Java HotSpot(TM) 64-Bit Server VM (build 25.31-b07, mixed mode)
Coldfusion version:
Coldfusion 11 developer version
Please help me how cani fix this error?
I have the same error. Adobe, please help!
i have the same error.
Please help
Same here. Trying to install Builder on 10.10.5
This happened due to version check failure on this particular version(10.10.5). Please upgrade to OS X El Capitan and then install it. It will install fine.
Adobe - krishnapreddy_adobe - I just purchased CF Builder 3 and it did not state that El Capitan is a requirement and is not compatible with 10.10.5. It's a pretty lame answer to say "[upgrade your OS]"! Some software isn't compatible with El Capitan yet...
THIS SHOULD BE FIXED IN THE INSTALLER... IT'S CLEARLY A POORLY WRITTEN REGEX THAT SEES 10.5 in 10.10.5.
ColdFusion Builder‌Adobe Coldfusion Builder 3 Installation Error on mac 10.10.5 - Unsupported Version‌ColdFusion‌
Joseph DeVore
@coldfusioner
a work around for this issue https://justindaigle.com/blog/2010/02/tutorial-change-mac-os-x-system-version/, change your OS version temporarily to 10.10.6 and run the installer, then change it back
