Hi Erin
First off, I'm pretty sure that things are just appearing
worse than they really are. Think of FEAR. It's an acronym meaning
False
Evidence
Appearing
Real.
Let's try and break it down a bit, shall we?
You said you have one project named PBMHelp. I'm assuming
this is the "Main" or "Master" project. So you inserted the merged
project and that one is named PBMNotes?
I'm a bit fuzzy when you refer to renaming something. You
said you used a different name? Did you rename the Master or the
Sub? If it's the Sub, you should be fine by just changing the name
back to what it was.
Assuming that I'm misunderstanding, it may help to just
return back to the bare bones basics. Delete the sub .CHM(s) from
any Master location. Double check the output locations of both
Master and Sub. Re-Compile each file and place both fresh files in
a common folder that is different from the project folders. Then
run the master and test.
Cheers and good luck. Rick
