Presenter 10 - (64 bit WIndows 7, 32bit Powerpoint, i7-3930 3.2GHz, 32 GB RAM) I installed the PptImgExporter.dll from a previous post, which solved the the ghosting radio buttons and made the multiple choice text reappear. However, the "Submit" and "Clear" buttons are transparent. The crazy thing is I have the default color on one question slide, and on another I color the Submit button orange. During the Publish, there is a point (~20% guessing on bar length) I can actually see the buttons turn invisible on my powerpoint slide. So Presenter is changing them during the Publish process. The new colored Submit and the default color submit are transparent in the output (HTML5 and PDF).
I just installed Presenter 11 and have the same problem.
Help.
I'm running into the same problem. Anyone find a solution?
Same problem here. Still no solution?
HI There,
I have shared the Dll files please download it and see if it works for you:
1. Click on the below link to download the patch :
2. Please download the zip file and extract it.
3. Please check the version of Presenter installed on your machine.
4. For 32bit: Please copy the PptImgExporter.dll from 32 bit folder and paste it under “C:\ProgramFiles (x86)\Adobe\Adobe Presenter 10.0”.
5.For 64bit: Please copy the PptImgExporter.dll from 64 bit folder and paste it under “C:\Program Files\Adobe\Adobe Presenter 10.0”.
6. Try to publish the project now and check.
Sidhartha
Presenter Engineering Team
Thank you, Sidhartha.
Does this work for presenter 11, too?
And do I have to paste it under Adobe Presenter 11.0?
Best regards
Hi There,
Fix is already present in presenter 11 build. Let me know if you are facing any issue using pn11.
Sidhartha
I'm using presenter 11 and it's still not working.
Everytime I fill the quiz buttons with a color, they become transparent while publishing oder previewing.
They also have a green mouseover. How can I change that?
Thank you
Regards
Hi There,
Sorry to hear this.
Please package your presenter content and the output folder and share it in dropbox and send me the link to my mail id @ sipanda@adobe.com
Sidhartha
Was this ever resolved in Presenter 11?
