Sorry to ask but I am struck and don't know where to go on. Any suggestions are appreciated. Here is the structure of the site. All the components are inside the components directory. With et directory, I'd like to create an Application.cfc for that. Files in et directory will call up functions in components directory. I tried to create this.mappings in et Application.cfc but don't seem to recognize or work. What do I need in sub Application.cfc (et folder) to call components?
Application.cfc (root application.cfc)
-components folder
-ce folder
-et folder
- Application.cfc
-index.cfm
-test.cfm
With the root Application.cfc, it has the following:
<cfcomponent displayname="Application" output="true" hint="Handle the application.">
<!--- set up per application mappings --->
<cfset this.mappings = {}>
<cfset this.mappings["/components"] = GetDirectoryFromPath( GetCurrentTemplatePath() ) & "components">
<cfset this.mappings["/ce"] = GetDirectoryFromPath( GetCurrentTemplatePath() )>
<!--- Set up the application. --->
<cfset THIS.Name = "Test" />
<cfset THIS.ApplicationTimeout = CreateTimeSpan( 0, 1, 0, 0 ) />
<cfset THIS.SessionManagement = true />
<cfset THIS.SessionTimeout = CreateTimeSpan( 0, 1, 0, 0 ) />
<!---<cfset THIS.SetClientCookies = true />--->
<cfset THIS.SetClientCookies = false />
<cfset THIS.loginstorage="Session">
</cfcomponent>
I could be incorrect, but I believe the application.cfc in your "et" directory is stopping CF from using the application.cfc in the root (CF iteratively looks for an application.cfc - once it finds one, it stops looking.)
So, your root app mapping is not being set if running .cfm/.cfc from "et" folder.
You _could_ conceivably set a mapping within your "et" application.cfc to the components folder in the root, but I'm not sure how well that would work.
V/r,
^_^
Bam! That's what I would do, too.
