I have created a newsletter page for a client and I would
like to give him the option of sending it via cfmail but I cant
seem to send the dynamic content as I get errors with nesting.
The page is pretty complicated but comes in fine until it is
in the cfmail tags.
Is there any way to copy the html of a page and send it to
another page to be sent by cmmail?
Error Occurred While Processing Request
Invalid tag nesting configuration.
A query driven cfoutput tag is nested inside a cfoutput tag
that also has a query attribute. This is not allowed. Nesting these
tags implies that you want to use grouped processing. However, only
the top-level tag can specify the query that drives the processing.
The error occurred in
C:\ColdFusion8\wwwroot\IAEsandbox\Indie\NewsLetterTemp.cfm: line
602
Called from
C:\ColdFusion8\wwwroot\IAEsandbox\Indie\NewsLetterTemp.cfm: line 51
Called from
C:\ColdFusion8\wwwroot\IAEsandbox\Indie\NewsLetterTemp.cfm: line 49
Called from
C:\ColdFusion8\wwwroot\IAEsandbox\Indie\NewsLetterTemp.cfm: line 1
Thank you for your response. I use the same code without the
CFMail tag and do not get and error. I have removed the information
but left all the tags so you could see that nothing is nested Query
in Query. Unless the CFMAIL tag is itself a type of query.
What if you created the email text in a varaible, then drop
it into the CFMAIL tag at the end. That would remove the nesting.
So, you would start a variable at the top and the variable
would contain all the HTML you want in the email. You then do all
you looping, conditionally adding info to the variable as you loop.
Then, at the end just drop the variable into the CFMAIL tag?
