Captivate v5.5
I have a project with a question pool and a series of random questions
The random question slides are without audio.
After finishing the question pool the project closes with the final slide which does have some audio - which runs fine when I test the slide.
However when I test the whole project (F12) the audio on the last slide does not play.
The audio on the slides prior to the random question slides plays without any problem.
Any ideas please?
Noel
Windows 8/Cap 7-- SAME ISSUE. I'm publishing HTML5-- i have quiz questions, a result screen, then a final slide that has audio. I'm currently trying to play around with possible solutions. A guy in another thread added silence to his question slides and said that that did the trick. I'll report back if it works... I can't wait to find another training program. Too many workarounds = wasted time. Maybe Microsoft's PowerPoint add-on, Mix, will do the trick? --rw
Adding a silent audio file to each question in the question pool did the trick. Hope this is still helpful to you. --rw
