Hi JimiZach, Mr. Howard, Captiv8r, Cazzamau, and others,
The original reported problem was with the static slide
before or after a dynamic (full-motion, or *FM*) slide, in that it
does not *transition* into or out of the full-motion activity. If I
am correctly reading the problem, this is nearly always easily
fixed - or more accurately, avoided.
Let's assume a scrolling action is going to trigger a FM
capture during your recording. You know exactly when this will
occur because it is a part of your storyboarding (design
considerations prior to recording), right? So ... build the
following into that storyboard, aka recording script.
Immediately
prior to the scrolling action, move the mouse to the point
you want to begin the scroll; carefully bring the mouse to a
smooth stop, then press PRTSCR (or its substitute) to force
a screen capture with the mouse stationary at the *beginning*
position.
After you hear the camera sound or see the tray icon *red
flash* to indicate a successful screen capture, immediately begin -
and complete - your SMOOTH scrolling action. It is very important
that you not jump or jerk at this point. If you are under 18 years
old you are probably used to moving the mouse at the speed of
light, so you might even want to have an older person do this part
for you. (C'mon, that was funny...)
Immediately
after the dynamic action is completed - and
before moving the mouse even a tiny fraction of an inch -
press PRTSCR once more, to force capture of a static slide - with
the mouse in the exact position it occupied at the end of the
scrolling or other dynamic action.
If you train yourself to do this every time there is to be a
dynamic action in your movies, I think your problems will be
eliminated, or at the least, decreased a considerable amount.
Hope this helps in the future, even if it is not much comfort
for problems that already exist.
regards~
Larry
