Java CLOB and BLOB to Actionscript VO
Avatar
Level 1
The Data Services backend is Java, Hibernate, and JBoss. I
have a table with a column that is a CLOB (character large object).
In Java the datatype is mapped to a java.sql.Clob and is easily
accessible from Java code. How do I transfer the Clob data to the
Flex Actionscript Value Object equivalent? I've set the data type
of the attribute to String and Object in the Actionscript VO but
all I get from Flex Data Services is a references to a managed
object. No translation to a primitive type is automatically done.
What am I missing?
Same question goes for BLOBs.
Thanks for the help!
1 Reply
Avatar
Former Community Member
This sounds like a worth candidate for an enhancement
request, I'll log one
for you on your behalf.
As a work around for now, can you convert your java.sql.Clob
to a char[]?
This should be returned as a String on the client. As for
java.sql.Blob,
can you convert that to a byte[]? This should be returned as
a flash.utils.ByteArray
on the client.
