Hi All.
I have am using CFGrid in HTML mode and it is showing a ton
of blank rows. There should only be 6 rows showing but it showing
24 blank rows. How do I go about using cfgrid and only showing the
rows that have data?
I assume u're getting data from a database, so either delete
all the empty rows or in your query filter out the empty records
<Cfquery...>
select * from tablename
where fieldname <> ""
</cfquery>
I'm having the same problem, except that I'm specifying the
href and hrefkey atttributes and it's adding a "-" character in the
blank rows and these rows have a blind link in them.
Is this just a problem with AJAX-bound HTML cfgrid, or is
there a way to avoid this?
Not sure if you got this already, but I achieved this when
binding to a CFC. One of the required parameters is "pagesize". I
do a quick check to see if query.recordCount is less than
"pagesize" and if it is, set pagesize = query.recordCount (see code
attached)
