Hi. I'm just in the process of looking into an upgrade from
version 5 to 7. I have a critical client project that involves
merging their RH5 help system into our RH5 help system, and I've
been accomplishing this by using Peter Grainge's techniques (thank
you, Peter).
My questions are:
Will this technique continue to work seamlessly if I upgrade
to RoboHelp 7?
If yes to the last question, and if our client does NOT
upgrade to 7, will I be able to import their help system project
files into 7 (pretty much as I do now in 5) and then perform the
merge using that same technique and with the same good results?
Or, will there be an even easier way to accomplish this in 7?
Thank you!
