Removed the entire creative cloud suite > restarted> ran the creative cloud cleaner > restarted > reinstall creative cloud > reinstall flash builder 4.7 > click to open and get an error to check logs
"See the log file
/Users/username/Documents/Adobe Flash Builder 4.7/.metadata/.log."
I'm on a mac running Yosemite 10.10.5 with JAVA 8, JRE 1.8. Could any of this be the problem? Here are the .log
!ENTRY org.eclipse.core.net 1 0 2015-10-02 14:22:07.244
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.067
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.project (68).
!STACK 0
org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at com.adobe.flexide.editorcore.EditorCore.initializeOptions(EditorCore.java:212)
at com.adobe.flexide.editorcore.EditorCore.start(EditorCore.java:160)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:760)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassName(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:456)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at com.adobe.flexbuilder.as.editor.quickfix.ActionScriptQuickFixRegistry.<init>(ActionScriptQuickFixRegistry.java:43)
at com.adobe.flexbuilder.as.editor.quickfix.ActionScriptQuickFixRegistry.getInstance(ActionScriptQuickFixRegistry.java:58)
at com.adobe.flexbuilder.as.editor.ActionScriptPlugin.<init>(ActionScriptPlugin.java:184)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:166)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.createFactory(PerspectiveDescriptor.java:171)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Perspective.java:744)
at org.eclipse.ui.internal.Perspective.createPresentation(Perspective.java:270)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:156)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(WorkbenchPage.java:1748)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.java:2535)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:637)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:796)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbench.java:1224)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3938)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3615)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:79)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.UnsatisfiedLinkError: no BridgeTalk in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at com.adobe.flexide.nativelibs.BridgeTalkInterface.<clinit>(BridgeTalkInterface.java:78)
at com.adobe.flexbuilder.project.internal.FlexProjectCore.start(FlexProjectCore.java:429)
... 149 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.075
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexide.editorcore (105).
!STACK 0
org.osgi.framework.BundleException: Exception in com.adobe.flexide.editorcore.EditorCore.start() of bundle com.adobe.flexide.editorcore.
Caused by: java.lang.NoClassDefFoundError: com/adobe/flexbuilder/util/PluginProperties
... 129 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.adobe.flexbuilder.project (68).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 134 more
Caused by: org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
... 143 more
... 149 more
Root exception:
... 134 more
... 143 more
... 149 more
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.081
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.as.editor (24).
!STACK 0
org.osgi.framework.BundleException: The activator com.adobe.flexbuilder.as.editor.ActionScriptPlugin for bundle com.adobe.flexbuilder.as.editor is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:171)
Caused by: java.lang.NullPointerException
at com.adobe.flexbuilder.as.editor.ActionScriptPlugin.log(ActionScriptPlugin.java:179)
at com.adobe.flexbuilder.as.editor.quickfix.ActionScriptQuickFixRegistry.<init>(ActionScriptQuickFixRegistry.java:50)
... 83 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.083
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.mxml.editor (65).
!STACK 0
org.osgi.framework.BundleException: The activator com.adobe.flexbuilder.mxml.editor.MXMLPlugin for bundle com.adobe.flexbuilder.mxml.editor is invalid
Caused by: java.lang.NoClassDefFoundError: com/adobe/flexbuilder/as/editor/ui/refactoring/IChangeRegionProvider
... 63 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.adobe.flexbuilder.as.editor (24).
... 68 more
Caused by: org.osgi.framework.BundleException: The activator com.adobe.flexbuilder.as.editor.ActionScriptPlugin for bundle com.adobe.flexbuilder.as.editor is invalid
... 77 more
... 83 more
Root exception:
... 68 more
... 77 more
... 83 more
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.136
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.ui (93).
!STACK 0
org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.ui.UIPlugin.start() of bundle com.adobe.flexbuilder.ui.
at com.adobe.flexbuilder.standalone.FlashBuilderWorkbenchWindowAdvisor.postWindowCreate(FlashBuilderWorkbenchWindowAdvisor.java:87)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowCreated(WorkbenchWindow.java:1347)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:816)
at org.eclipse.ui.internal.Workbench$24.runWithException(Workbench.java:1238)
Caused by: java.lang.NoClassDefFoundError: com/adobe/flexbuilder/project/FlexBuilderInstallation
at com.adobe.flexbuilder.ui.asn.ASNUIBridge.start(ASNUIBridge.java:53)
at com.adobe.flexbuilder.ui.UIPlugin.start(UIPlugin.java:106)
... 50 more
... 31 more
... 143 more
... 149 more
Root exception:
... 31 more
... 143 more
... 149 more
!ENTRY org.eclipse.osgi 4 0 2015-10-02 14:22:08.168
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/adobe/flexbuilder/ui/handlers/OpenStartPageHandler
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.adobe.flexbuilder.ui (93).
... 35 more
Caused by: org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.ui.UIPlugin.start() of bundle com.adobe.flexbuilder.ui.
... 44 more
... 50 more
... 31 more
... 143 more
... 149 more
I still have not figured this out. Anyone else ran into this issue? Any help would be greatly appreciated..
the same issue. didn't start
In case this helps anyone else:
I had the same error in El Capitan. I had to do the following to fix it, since FB requires the legacy Java 6 runtime.
1) Download Java for OS X 2015-001
2) cd /Library/Java/JavaVirtualMachines/
sudo mv jdk1.8.* ../
3) That should only leave jdk1.6.x in there.
Now FB should start.
This worked for me! Thanks!
macOS High Sierra v10.13.3
