Robohelp 7, Windows XP, installed with the TCS
How do you point RoboHelp to a different JavaHelp viewer
instance after it has been set initially? I was first using
JavaHelp 1, but then installed JavaHelp 2, and I want to switch
between the two for viewing, as I compile for the different
versions. The only way I found to do it was to change the path to
the active viewer which causes RoboHelp to lose it and to ask you
again where it is.
And by the way, I looked in the help for this and I got some
whacked out non-scrollable window that seemed to search the Adobe
website, rather than provide help. Am I doing something wrong? It
didn't look like a help system at all.
Russ
