CF equivilent to asp.net
Aug 06, 2007 Aug 06, 2007
i have a page in asp.net (vb) that references external data objects (dll file in the bin folder) and i wondered if it is possible to do in coldfusion, i would assume javascript would be the only option. it is sage data objects and here is a preview of the code in vb.net.
Dim oSDO As SageDataObject130.SDOEngine
Dim oWS As SageDataObject130.Workspace
sage say any language that supports COM objects will work, so does javascript and how to you add a reference to a dll or tlb file?
Advanced techniques
483
ColdFusion has the <object ...> tag and createObject() function that can
both be used to run com objects. ColdFusion can also execute command
line syntax with the <cfexecute...> tag.
I am not familiar enough with ASP.NET to know exactly what a data object
is. Is this just connecting to a database or something else? For the
form, ColdFusion developers usually use the <cfquery...> tag.
<cfquery name="myRecordSetVar" dataSource="myConfiguredDSN"...>
SQL Syntax
</cfquery>
Other then that, you will have to tap somebody who knows there ASP.NET
details better.
Feb 21, 2008 Feb 21, 2008
<cfset SDO = CreateObject("com", "SageDataObject130.SDOEngine")>
<cfset WS = CreateObject("com", "SageDataObject130.Workspace")>
That should be what you need for com objects. You would then call the methods by using <cfset returnResult = WS.method(variables)>
Read up on the CreateObject fucntion in livedocs.
Bob
Apr 16, 2008 Apr 16, 2008
i have pulled my hair out but cannot get CF to work with this com object, i just get An exception occurred when instantiating a COM object.
Invalid com object, the object is registered fine and works ok with asp.net and javascript?
Documentation
