I'm working with a comma delimited file. In some fields, I
run into a situation like this:
, "1,0000",
The first comma and the last comma are delimiters. The comma
that is enclosed within the quotes is causing the problem. Is there
a replace function that can find the " then kill the comma, but
still leave all the delimiters alone?
cfhttp may be helpful. After you upload the file you can use
the name attribute to convert it to a query. There is something in
there as well where you can specify quotes.
I've continued to modify the original code. I'm now using a
Regular Expression to try and speed this up. I've also nested some
of the code. If you can think of ways to speed this up, into more
of a one line REReplace type function, I'd appreciate the input.
