> I tried to run cmd.exe and facing the same problem with
it.
> actaually i want to run a java application on sever .
And it's a *command line* Java application? Does it not have
an API?
What happens when you go:
<cfexecute name="/path/to/java.exe"
arguments="/path/to/your/app other args
here">
Bear in mind that the system a/c that CF uses bt default has
very few
permissions, so you might need to check it can see the
various files needed
to execute the app.
Adam
