I am experimenting with RoboHelp 2015 trial version. I imported the framemaker files and in the Project settings tab I was able to select para and char settings via the + sign in 'Edit Conversions settings' in the Project Settings tab, but now after generating the plus signs are not there and I have no option to edit, please advise.
What source are you using? Word? FM? Linked or imported?
I figured this one out Jeff, thanx anyway.
Cheers,
William
William, I'm pleased you sorted the issue.
Can you tell us what you did to resolve it? Your response could help others down the road.
Thanks... Rick
Sure np rick - To update FM conversion settings, go to the Project tab, select Settings, click on 'Edit conversion settings for FM documents'; if you find there are no expand plus signs next to Paragraph and Character (the problem I encountered), cancel out of that window and back to the Project tab, then click on the Update button; now try again clicking on the Settings and Edit conv. settings button; this time you should see the plus signs so that you can edit styles and specify paginations..
-Bill
