I must be very stupid.
How do i acces a global variable is a pdf form in ES4???
Variables.name.rawValue does not work...
topmostSubform.Page2.CodeElementen.txtCijfer works fine... for an object... where txtCijfer is a box.
Can find it on google...
Many Thanks!!
Total Likes
If it is declared as a global variable in the PDF it should be .value instead of rawValue
Hope this help!
Total Likes
Still does not work... partly:
if (this.rawValue < 0.666) {
xfa.form.topmostSubform.onvoldoende1.value = 1; // think my path is wrong, but can't figure out what it should be...
Does not work...
"this.rawValue = onvoldoende1.value" does work somewhere else...
Total Likes
I think just using the name value should do the trick
To make a integer value accessible, you would have to create your own script object and have get;set; functions
By keeping the global variable as the accessible value, if you want to use it as an integer to use it for calculation you can use
Hope this help!
Total Likes
