CFCalendar in loop?
Feb 23, 2008 Feb 23, 2008
Is it possible to create multiple <CFCalendar> tags in a loop?
I have a loop that creates a unique form for each record in a result set. My goal is to create a calendar for each of the records and use the form to allow updates to a due_date field related the record. I have used the following code (stripped down to include only necessary sections) to attempt this. When I do, only the first CFCalendar loads. I assume this has something to do with how the CFCalendar is integrated with javascript.
Is there anyway to accomplish this?
<cfloop query = "DueDateResultSet" >
<cfform format="html" name="CalenderForm_#DueDateResultSet.order_unit_id#" action="DueDate_Update.cfm" >
<cfcalendar
name="Calendar_#DueDateResultSet.order_unit_id#"
mask="mmm dd, yyyy"
dayNames="SU,MO,TU,WE,TH,FR,SA"
monthNames="JAN, FEB, MAR, APR, MAY, JUN, JUL, AUG, SEP, OCT, NOV, DEC"
style="rollOverColor:##FF0000"
width="200" height="150"
</cfform>
</cfloop>
Advanced techniques
351
I don't know why your calendar does not load, but I'm curious about why you have more than one form. The user can only submit one of them.
By the way, I see no cfoutput tag. Is that something you stripped away for brevity?
Finally, how many records did your query return?
I went with separate forms as the requirements call that the user should only submit one update. In fact, the business rules never call for a scenario to be updating more than one at a time so I thought it would be easier just to break them out as individual forms.
Regarding the <cfoutput> tags. I do not have cfoutput tags around the calendar section, but it does not appear to be affecting the dynamic outputing of my calendar name. When I do a view on source of the output page, I see name="Calendar_6665758" which is what I expected. I tried to include the <cfoutput> around the <cfcalendar> but it did not make a difference.
The query is returning 2 records.
Feb 24, 2008 Feb 24, 2008
Well.. not sure why, but when I pull the <cfform> tags out of the loop, it did work successfully showing a new calendar for each row. Thanks Dan for leading me in the right direction with your question.
Documentation
