How do I reset the layout in Premiere Pro?
Aug 16, 2013 Aug 16, 2013
Out of nowhere, when I open a project or create a new project in premire pro I can not see what I am doing.  The windows are all off screen somwhere. When I start up the program -the menus appear in strange, off-center positions on my screen-this has never happened before. Please help!
How to , User interface or workspaces
153.0K
Reset Corrupted Preferences = Press/HOLD Ctrl+Alt+Shift while starting program
-and setting http://forums.adobe.com/thread/1058426?tstart=0
Aug 21, 2013 Aug 21, 2013
Thanks, John T Smith! I will keep this for reference should that problem arise again.   Your suggestion most likely would have worked, however I reinstalled and evernything did go back to normal.  I hope this doesn't happen to anyone else, but when I had the problem, if I clicked "reset workspace", changed preferences, etc....anything I did wouldnt bring up the workspace screens.  I have not used external display.
Adobe Employee ,
Dec 18, 2015 Dec 18, 2015
Frank, check out this page which discusses Premiere Pro workspaces in detail: Use and customize workspaces in Premiere Pro
Nov 26, 2017 Nov 26, 2017
I had this same problem just now. For no reason whatsoever, the graphics panel just completely turns up blank. Restarting and resetting didn't help. I'm going through all the possible windows one by one but the sequence itself is just not showing up so I can't work on any graphics. I did not make any changes, no added external monitors or changes to the workspace, no significant changes to any files involved.
Adobe Employee ,
Nov 27, 2017 Nov 27, 2017
Sirje: Does resetting the layout (Window > Workspaces > Reset to Saved Layout) fix your blank Graphics panel problem? If not, what about following the steps I outline in this thread (scroll down to find my 6/30/17 post): How do I reset Premiere Pro CC windows to default settings ?
Jan 02, 2018 Jan 02, 2018
I just tried this tip and it completely reset my project file eventho I saved it and it was autosaved regularly, is there any way to reset this step?
1 person found this helpful
Adobe Employee ,
What if you open one of the autosaved project files?
Nov 09, 2019 Nov 09, 2019
This didnt work for me to realign the workspace... 😞
Alternatively, you might just be able to go to the "Windows" menu and hit "Reset Current Workspace".
By chance, have you connected or disconnected an external monitor lately?
Oct 07, 2015 Oct 07, 2015
OH MY GOD!! so easy... just been figuring out the last hour how to do just this! Thank you
In case you're not aware, you can move your windows around the screen, resize them, and in general configure the screen to suit your working style then save this arrangement (in CS5 - Window>Workspace>New Workspace - give it a name, ok). You recall this arrangeent by going back to the Window>Workspace and select it, or choose one of the defaults. Or, open the little Workspace window (top upper right of main screen) and pick an arrangement.
Of course, you can create several custom workspaces to suit your specific task on hand.
I solved this problem by changing my screen resolution settings to low resolution (big horsey icons and everything), which brought back the window, then I changed it back to the normal (non-horsey) resolution and it was fixed.  I hope this works for you guys!
